bzgenius
Jun 09, 2017Explorer
water pumps
I am just about to put the camper back together but wanted to check for water line leaks and low and behold the dang pump wont work. It sounds good and when I took it apart nothing looks worn out or out of place so I guess its just to old and been sitting to long. It is a shurflo 2088-403-144 and I did find replacements online but some questions for you all first.
1# Is there a reason to put something better in or just replace with original?
2# Should I replace it all or just the plastic pump part since the motor works fine?
Positive note is the hot water heater fired right up, the fridge works and the holding tank doesn't leak. I will be glad when this project is done and usable.
