inthedark's avatar
inthedark
water tank replacement
I have just got a 2003 arctic fox that has a hole in the top of the fresh water tank. any idea what it takes to replace it? does not look like its going to be easy to get at.
  • Well didnt want to ask-but thought maybe in the fix a lil description of the 'hole' and or how it got there might have been included. But an 'Easy' fix on the water tank material would be good to pass on.
  • inthedark wrote:
    Thank you all. turns out its a pretty easy fix. factory is friendly and helpful.
    So what did you do?:@
  • Thank you all. turns out its a pretty easy fix. factory is friendly and helpful.
  • Tank-Depot.com
    Call them and ask.
    My guess? THe prior owner probably thought "How do I reach in there and clean the tank? Then got out a hole saw, and you now have a easy wash tank system. That leaks when going around a corner. Opps!
    You might be able to get a 12" square patch, and glue it over the hole. Or O-ring and screw down the patch, so you can remove and clean again?
    Fred.
  • Oh, one more thing. On my Host, my tank is accessible from the front. Your's could be similar, but based on what people have posted, I don't think it is. Using a waterproof hatch, is a good idea.
  • AimlessWanderLust wrote:
    Would it be easier to just patch the hole? Not sure how big it is, but there might be some sealants to patch it. Or if it is a big hole, you could maybe even cut it bigger and install a marine access hatch like NetBoy.
    NetBoy DeckPlate
    X2
    Was thinking of the same thing with the hatch.
  • Would it be easier to just patch the hole? Not sure how big it is, but there might be some sealants to patch it. Or if it is a big hole, you could maybe even cut it bigger and install a marine access hatch like NetBoy.
    NetBoy DeckPlate
  • I think the floor will come off and it is probably held up by straps. People have said that the factory is good about answering questions. I'd call them.
