Ron_Gratz
Jun 21, 2015Explorer
Timtation wrote:In a post on 10/5/14, you stated:
Ours is currently the Draw-tite hitch. I will look into the Anderson.
"TV is a 2011 Ram 1500 with the 5.7 Vortec, Plenty of torque for the job which is a very heavy 2003 25' TT,---"
If you are towing with a 2011 Ram 1500, you probably need a WDH which can restore 100% of the load which was removed from the TV's front end when the TT was hitched.
If you are towing a "very heavy 2003 25' TT", its tongue weight probably is heavy enough that the Andersen WDH would not be able to achieve 100% Front Axle Load Restoration.
It would be a good idea to know what the loaded tongue weight is before considering an Andersen WDH.
Ron
44,070 PostsLatest Activity: Aug 07, 2026
