Walaby's avatar
Walaby
Explorer II
Feb 11, 2016
WD Hitch Setup Question
I recently upgraded my TV to Ram 2500 Cummins Turbo Diesel, and just because I got a bigger, badder truck, wife and I decided we needed a bigger, badder travel trailer. Got a 2016 Lacrosse 324RST. Just picked it up today. Really liking the rig and the deal we got.
Anyways, the dealer set up the WD hitch. It's a Husky Centerline TS. 1200lb bars. I used it on my old TT, and really happy with the hitch.
I weighed the truck full tank of gas (no passengers). I know I will eventually weigh full passengers etc, but since I was by myself, decided to weigh it just full gas no passengers. Weights on each axel were
Front: 4820
Rear: 3080
Total 7900
Weighed it again today, with TT trailer hooked up dry (I know, will weigh again fully loaded). Got these weights
Front: 4500
Rear: 4580
Trailer Axle 7700
Gross weight 16780
So, the current WD setup is taking 320 lbs off the front axle. Im thinking I want to adjust it to put more weight back to the front axle. It drove fine, didn't seem to have any issues with the less weight on the axle. Of course, adding my wife and I will put that much weight back on the axle, so maybe I should just leave it.
I've got 1180lb tongue weight, based on these numbers. Total trailer dry weight is 8880lbs. That includes two 30 lb Propane tanks full, and the battery. Im thinking I might need to go to a higher capacity WD hitch, since my bars are 1200lb bars and thats the highest the Husky Centerline has. 1180 lbs is 13% of the total weight.
So, guess two questions...
1) Should I adjust WD hitch to put more weight on front axle, or not worry about it, since adding passenger weight will bring it up. And, of course, that will be countered by whatever I load up in the front storage compartment, once Im loaded for travel.
2) Should I find a WD hitch with 1400lb capability? My hitch and my shank is rated for 1400 for WD hitch. Im guessing so, given the fact that if I keep my tongue weight at 13% I will be at 1285 tongue weight.
The truck and trailer do sit level, and I have the before measurements of the wheel wells, just haven't taken the after measurements yet, and it's dark out, so I can measure them later to see if the front has lifted up. Im guessing it has some amount.
I will be weighing it again fully loaded, but if I should adjust the hitch, I can do it easily enough now.
Thanks in advance for your thoughts.
