I would sure like some ideas where to store the spring bars when not hooked up. I have the Reese Strait-Line dual cam WD which pretty well takes the A frame out.
I have the same hitch as the OP. After I drop the cams and swing the bars away from the cams I hook up the cams back up with 3 links "under tension" and then remove the bars from the hitch head and slide them onto the cams, dirty end out and clean end balances against the cross piece under the A frame. That allows me to always keep the bars on the same side.
