So we brought home our tt with the wdh and sway bars adjusted at the dealer- all looked great. My question is after everything is loaded for the first time, do I need to go back to the dealer for anot...
I would measure my truck height before I hook up and check for height drop after I'm hooked up. If the drop is within an inch and a half and the trailer is still level I would say your good. If not you could try tightening your torsion bars by using 1 less chain link. If that won't work you can also adjust your hitch head height. I would suggest you check out you-tube or e-trailer for some of their excellent videos.
