I am thinking of getting a new trailer and WDH. How do I know what size/weight spring bars to get?? Is it the same as the hitch weight, meaning - if I have 750 pounds of hitch weight do I get 750lb b...
The bars have a range of weight that they handle, see the manufacturers website. Barney suggested bars that are above the weight you stated, knowing that the hitch weight is almost always well above the published weight. If you could get the real weight ready to roll it would help you get the exact bars you need. Know that heavier isn't better, correct is best since they need to flex.
