Campfire Time wrote:
AH64ID wrote:
Some references call for all the weight to be restored to the front axle and some call for 50%.
I am about 50-60% on my setup and it tows great.
What references? The only one that's accurate is your tow vehicle's owners manual.
Your owners manual should have a spec for this. With GM, you are supposed to measure the front fender before adding the trailer. Then adjust the hitch to bring the front fenders back to stock height.
Your understanding of the GM spec applies only up to about MY 2012.
For the past 3-4 years, GM has specified that the WDH should be adjusted to eliminate only about 50% of front-end rise, for most TV/TT combinations, when a WDH is required.
Ron
