Trackrig
May 11, 2016Explorer II
I don't see any reason not to do it, just a word of caution. Clothes weigh a lot and they bounce up and down. When you put in the pole, I'd use a piece of pipe instead of a standard wooden hanger pole. While you need to attach it to the end walls to keep it in place, the end walls of former bunks can't handle all of that weight. Use 1x4s or 2x4s at the ends of the pipe to support the actual weight onto the floor. Maybe even a support in the middle of the pipe also. If you're not over a frame rail in the floor, use some extra support where the 2x4 will be on the floor like a piece of 3/4" plywood under it.
Bill
Bill
44,029 PostsLatest Activity: Jan 21, 2025
