Lessmore
May 10, 2019Explorer II
When the going gets tough ie; stuck.. in a regular 4WD...you have 2WD...one wheel in the back turns, one wheel in the front turns.
With the addition of a locker or limited slip in the rear axle of a 4WD...when you're stuck...you have 3WD...two wheels in the back are turning...one wheel still in the front is turning.
They're are some 4WD trucks with actual 4WD when you get stuck...ie; locker/limited slip rear and locker/limited slip front axle...in this case when you get stuck...all 4 wheels are turning...I think maybe only the Ford Raptor maybe so equipped. I'm sure others would know for sure if there are others.
