wnjj
May 10, 2019Explorer II
Lessmore wrote:
When the going gets tough ie; stuck.. in a regular 4WD...you have 2WD...one wheel in the back turns, one wheel in the front turns.
With the addition of a locker or limited slip in the rear axle of a 4WD...when you're stuck...you have 3WD...two wheels in the back are turning...one wheel still in the front is turning.
They're are some 4WD trucks with actual 4WD when you get stuck...ie; locker/limited slip rear and locker/limited slip front axle...in this case when you get stuck...all 4 wheels are turning...I think maybe only the Ford Raptor maybe so equipped. I'm sure others would know for sure if there are others.
That's kind of true but when all of the wheels are in slippery stuff, they will all receive some power.
