My Starcraft is a year older then yours and started doing the same 2-3 years ago. When it rained heavy I could see the lower portions of the zip up windows were wet. I first used
Seam Grip on
all the seams. once that dried I used
Trek 7 to spray the zip up window covers  both inside and out, a couple times. The zip up part seems to be a lighter type of material. I've had no issues since.
 When I sprayed, I tried to be careful not to get the spray on anything but the window covers as I didn't know if it would have an adverse reaction the the Aqualon sides and roof.
If you are interested, this from a custom canvas shop, Nelis: Aqualon
Aqualon was previously sold somewhat frequently by Nelis Customs to offer a fabric similar to a popular Aquaknot branded fabric sold by another shop in Pittsbrugh, hoevever it has been all but phased out of our lineup of recommended fabrics at this point due to their being what we consider better alternatives that are equally affordable on the market.  While we are phasing it out and recommending better alternatives, it does have its uses and we will continue to offer it as long as it continues to have a 5 year manufacturers warranty because it is an affordable and somewhat durable vinyl coated polyester marine fabric that weighs just 9 oz. per square yard which can come in handy.  Aqualon offers a manufacturer's 5 year limited warranty to not crack, peel, harden, discolor, or flake.  We caution using Aqualon and feel there are better products on the market because its coating is only applied to the top side and seems to be more fragile these days, but if you are looking for the absolute cheapest material Nelis Customs will use - this is it.  The issue with Aqualon in our opinion is the durability of the vinyl coating which we have found to be easy to scratch and damage when the cover is pulled across something other than a smooth surface when installing on the boat.  Nelis Customs plans to phase out Aqualon in 2010 and replace it with a more durable, equally priced, alternative called Harbor Time.
