SDcampowneroper
May 07, 2018Explorer
With the power usage you describe, a group 24 battery should last a couple of days without discharging below the damaging 11.8 v 50% threshold. Are you sure of your minimal usage?
Furnace, water pump are power hungry devices you cannot avoid. Upgrade lighting to leds will make a difference, maybe not enough to match your needs.
You cant have too much battery. Economically a larger battery or second battery wired in series is the better long term cheaper option.
