MitchF150
May 07, 2018Nomad
Check to see that the moisture switch is off in the fridge.. At least on my fridge, there is a switch that when turned on is supposed to keep the moisture buildup in the fridge to a minimum.. Not really sure of it's purpose, as I've never kept it on..
The switch on mine is inside the main fridge door on the upper sill. Simple toggle switch. It uses 12v power, so if it's on and you are only on battery, it could use a lot more power.
Lots of other things that suck power from just being 'on' so might need to do a power audit of your rig.
Good luck!
Mitch
Good luck!
Mitch
44,072 PostsLatest Activity: Aug 23, 2026
