SoundGuy
May 09, 2018Explorer
postmandug wrote:
@Soundguy
And why would I need to totally unplug my TV? It’s 120V only....
Your's is a newer model year 192RBS than mine but you might what to check that your television won't indeed run directly off 12 vdc, as does mine. I ditched the 12 vdc > 120 vac power supply as it's just not necessary. By powering the television on 12 vdc you can then use it while dry camping but it's a good idea to disconnect it entirely from that 12 vdc supply when you're not using it as the television still draws power even when you turn it "off".
