Ron_Gratz
Sep 17, 2015Explorer
Danford50 wrote:Chevrolet specifies that your WDH should be adjusted so that 50% of the front-end rise is eliminated.
when hooking up the weight distribution how tight should i put on the torsion bar, currently i am hooking in to the fourth chain link
Or, if you have access to a scales, adjust the WDH so that you restore 50% of the load which is removed from the front axle when the TT is attached with no WD applied.
You can find the adjustment instructions on Page 9-91 of the Owner's Manual.
To increase the amount of load transfer to the front end, you can increase the amount of rearward tilt of the hitch head and/or decrease the number of chain links under tension.
For most WDHs, you should have at least 5 links under tension.
Don't worry about making the TV "level".
When you get the front end at the proper height, the rear end will take care of itself.
Ron
44,027 PostsLatest Activity: Apr 19, 2019
