This is a silly question I am sure, but here it goes. I know you can weigh your rig at a truck stop on their scales. I was wondering if you can use those random truck scales on the side of the high...
The debated comes down to the tongue weight your hitch carries.
Without the WD the full weight of the hitch is on the ball and the rear springs compress.
With the WD hitch some of the weight is transferred from the ball reducing the rear spring compression and reducing the axel weight and increasing the front axel and trailer axle weights.
Either a person believes it or does not. It may make for an interesting discussion but it has little impact on the overall RV community.
