nickthehunter wrote:
JIMNLIN wrote:
...The biggest joke of the tire placard payload system is a F150HD with a 8200 or 7750 GVWR and 4800 RAWR. Ford advertises this truck can have up to a 3000+ lbs payload.
These trucks may weigh in the 2400 lb range on the rear axle. Now add the 3000 lb payload sticker number in the bed = 5400 lbs on the 4800 RAWR. Another seriously overloaded vehicle as the F150 rear suspension and Fords OEM wheels aren't rated that high...
I don't believe you. Can you show me an example of a F150 that Ford advertises as having a payload of 3,000 + lbs and weighs 2400 lbs on the rear axle from the factory?
Now where did I say the F150 comes from the factory with a advertised 2400 lb number. The 2400 lbs number I used above (quote)"These trucks may weigh in the 2400 lb range on the rear axle" came from a F150HD owner who said his rear axle weighed just over 2400 lbs and adding his trucks 3000+ lb payload in the bed over loaded his trucks 4800 RAWR.
However even Fords body service spec web
https://www.fleet.ford.com/truckbbas/non-html/2016/2016F150_Technical%20Specs_SB.pdf show a '16 F150HD 7850 GVWR 4800 RAWR with a 1883 lb rear axle weight has a 3240 lb payload.
Simple math shows 1883 rear axle weight with 3240 lb payload sticker number in the bed = 5123 lb on the rear axle.
Remember the payload number on the tire placard is a GVWR based payload.
