SouthpawHD wrote:
gattorgetter wrote:
Sometimes its easier to ask over there without getting the " you need a bigger truck"
That's for sure!!
Thats double for sure.
Tire placard payloads are based on the trucks GVWR which in some cases can overload the trucks RAWR/tires/wheels and rear suspension when placed in the trucks bed.
The biggest joke of the tire placard payload system is a F150HD with a 8200 or 7750 GVWR and 4800 RAWR. Ford advertises this truck can have up to a 3000+ lbs payload.
These trucks may weigh in the 2400 lb range on the rear axle. Now add the 3000 lb payload sticker number in the bed = 5400 lbs on the 4800 RAWR. Another seriously overloaded vehicle as the F150 rear suspension and Fords OEM wheels aren't rated that high.
Same for some of the new high GVWR 3/4 and one ton SRW gas trucks.
