lawrosa
Jan 03, 2015Explorer
IMO from calculating GVW that vehicle should not pull more then 7600 lbs... That camper is that weight dry...
But if you insist on pulling it what are the tire ratings??/ What is the psi in the tires of truck ??? My advice is inflate to max front and back... The sway will go away IMO...
Input here...
http://towingplanner.com/ActualWeights/TravelTrailerCatScales/?w1sa=2620&w1da=4600&w1ta=8440&w2sa=1840&w2da=5600&w2ta=8160&w3sa=2660&w3da=3380&a=2
You never want more weight on front wheels then stock...
IMO you are good all around and best your going to do...
Input here...
