stationaryfullt
Jan 04, 2015Explorer
Weight calculations-2008 Jayco Eagle and 1991 Suburban
I took a set of scale readings after making some changes to my hitch setup and trailer loading to try to make the towing experience better. I was previously having issues with being pushed to the side when 18-wheelers passed by. I figured out that I needed another 200 pounds returned to the front axle, which prompted the changes.
The tow vehicle is a 1991 Chevy Suburban R1500 that I've upgraded the axles, brakes, suspension, tires, etc to 1-ton parts. About the only part of the truck that's not 1-ton is the frame, and the difference in a 1/2 ton and 1-ton frame is .02" of thickness. It has a Draw-Tite receiver hitch with a 10,000/1,200 rating. The weight distributing hitch is a Reese Strait-Line with 1500 pound bars. The camper is a 2008 Jayco Eagle 32RLS.
Here's the scale readings:
Truck ratings (original half-ton ratings, not 3/4 ton ratings):
GAWR-Front: 3250
GAWR-Rear: 3968
GVWR: 6800
Truck only loaded for camping:
Front:2660
Rear: 3380
Trailer: 0
Weight distributing bars unhooked but on trailer tongue:
Front: 1840
Rear: 5600
Trailer: 8160
GCVW: 15600
Weight distributing bars hooked:
Front: 2620
Rear: 4600
Trailer: 8440
GCVW:15660
To be fair, because I know this is going to come up, YES, I know my rear axle is over the door plate rating by 632 pounds, but, in every way except the frame, from the axle, to the suspension, to the brakes, this is a 3/4 ton truck with 3/4 ton ratings. I've done extensive research from GM's limited data offerings and determined the differences between the 1/2 ton and 3/4 ton models of this truck from my year. But to play devil's advocate, I kept the 1/2 ton ratings.
By my calculations, that put me up to 1400# of tongue weight. I hope I'm wrong on those calculations, as that puts me 200# over the receiver hitch rating. I moved weight around in the trailer in an attempt to get more tongue weight to help the issue I was having trouble getting blown around by big rigs passing, and it worked. I didn't have any trouble at all with big rigs blowing by. I guess I need to figure out how to move 200# off the tongue.
Am I correct in my calculations and going in the right direction?
GAWR-Front: 3250
GAWR-Rear: 3968
GVWR: 6800
Front:2660
Rear: 3380
Trailer: 0
Front: 1840
Rear: 5600
Trailer: 8160
GCVW: 15600
Front: 2620
Rear: 4600
Trailer: 8440
GCVW:15660
