Seattle_Lion
Dec 28, 2013Explorer
Weight calculations for dummies
I have read all of the threads on GVWR, tongue weight, etc. and I am still confused. Since I am an engineer, I suspect it isn't the math that bothers me. After a lot of painful reading, writing, and calculating, we determined that my Ford F150 was going to be over GVWR by a few hundred pounds. So, I traded it for a new F350 Diesel. I know it has the capacity. What I can't do is figure the numbers.
According to the door sticker and the window sticker, the truck has the 11,500 lb option. The door sticker says we have a 11,500 lb GVWR. So far so good. Nowhere on the sticker or elsewhere on ford data sheets is there a value for the truck's weight. On the wheel and tire sticker, it says that max load for the truck is 3,500 lbs. I assume that is based on the capacity of the tires (SRW model). I still don't know what Ford says the vehicle weighs.
Edit I did some further research (using the tables referenced below). According to the Ford tables:
The GVWR is 11,400 (per sticker)
Payload for the crew cab 4X4 is 3,870. That would make the calculated vehicle weight 7,530 (more sensible to me). So the tire/inflation sticker claims 3,500 lb capacity and Ford 3,870. More confusion.
We went to a closed state weigh station the other night. The scale (there are two platforms about 40 feet apart) isn't big enough on a single platform to hold all four wheels. So we weighed the front and back wheels separately. Front weighed 5,460 and the rear 5,300. It makes no sense that the truck with just us in it weighs 10,700 lbs. That would give us less than 1,000 lbs load carrying. Also, even though I am not a mechanical engineer, I am pretty sure that weighing front and back separately and adding the results does not give true weight. An f350 can't weigh 5 tons! I am guessing it should weigh between 7 and 8,000 lbs.
There are lots of numbers on the stickers and on ford's spec sheet (Ford Truck Specs).
We will look for a bigger scale. In the meantime, there must be a way to get a reasonable estimate of what the truck weighs.
What does the 3,500 lb capacity number on the tire and inflation sticker mean? Is it a truck spec or tire capacity?
Any idea what the truck weighs?
How do you use the axil weight ratings. I assume to calculate load, you first need to know what weight the truck puts on the axil and then the difference is the capacity (like for a 5th wheel). If you go by the readings we got when weighing each axil the other night, there is virtually no capacity.
Your help would be most appreciated.
