- JIMNLINExplorer III
Gooseneck & 5th Wheel trailers have a different geometry from bumper pulls as they are shooting for 20-50% of the weight on the hitch
Looks like your experience with owning and pulling rv and working non rv trailers has been different than mine. Before making claims about my trailers suspensions you need to do some home work prior on what trailers I have and see the different suspension setups out here on non rv trailers. Their not all the same.
My 38' GN triaxle stock trailer and other flatdecks suspensions are set up no different than big 5th wheel/toy haulers for 15-25 percent hitch weights. Even my 18' and 22' bumper pull car haulers suspensions are set up as a TT with 10-15 percent hitch weight. I bought them this way so they can be pulled with a heavy duty 3/4 ton truck.
Your point of non rv trailer suspension set ups has been made before but in the real world not all are as you claim. Sure we have various types of non rv trailers that their suspensions are set farther aft which....but not all are as such.
That 200+ lb was a measured weight number on the hitch from the 2200 lb bull. All my trailers are pulled level.
A teeter totter principle of a center balance point is a poor example of how suspension work on trailers especially with multi axles. Point is adding 300 lbs on the back of the tandem axle trailers rear bumper won't make the hitch weight lessor the same amount. - valhalla360Navigator
JIMNLIN wrote:
I've loaded several hundred GN/pintle hitch flatdeck and stock trailers and was always surprised how small the percentage was of adding a load on the azz end of the trailer and changes hitch weight.
First off the center of the axles doesn't work like a teeter totter #1 because one end sits on the trucks hitch. #2 can be distance behind the last axle spring hanger and #3 is the distance from the hitch to the first axle spring hanger. Without seeing the trailer I wouldn't guess a weight.
Loading a 21000 lb 38' GN tri axle stock trailer with young stuff....cows...and big mature bulls is a guessing game. I know adding the 2200 lb bull in the last stall didn't change the weight on the ball by a quarter of a inch = approx 200+ lbs.
Adding 300 lbs on the rear bumper of a small TT IMO can make a ill handling combo.
Assuming you keep the trailer reasonably close to level, the weights do transfer like a teeter totter:
#1 The teeter totter is purposely out of balance with the front end longer than the back end. This would be like putting a 10ft arm on one side and a 5ft arm on the other end...to keep the teeter totter level, you would need a lifting force (ie: hitch weight) under the rider on the long end.
#2 & #3 Unless The trailer is wildly out of level, this won't have an impact as the springs will give pretty closely approximating a central pivot point.
Gooseneck & 5th Wheel trailers have a different geometry from bumper pulls as they are shooting for 20-50% of the weight on the hitch (semis are typically around 50%). This means the trailer wheels are set much further back typically. As a result, the moment created by a weight put way at the back has far less impact on the pin weight.
- Bumper pulls travel trailers tend to have the wheels centered 55-60% of the length back from the hitch. So weight placed a few feet behind the rear bumper will tend to remove 80-100% of that weight from the hitch.
- 5th Wheels tend to be 65-75% back from the hitch. This will result in a similar weight removing 30-60% of the weight from the hitch. Add in that the hitch weight is much higher to begin with and you can absorb more weight without significant impact on the handling. On a lot of commercial GN trailers, the trailer axles may be 80-90% back and it may only remove 5-20% off the hitch (hence your 2000lb bull example) - JIMNLINExplorer IIII've loaded several hundred GN/pintle hitch flatdeck and stock trailers and was always surprised how small the percentage was of adding a load on the azz end of the trailer and changes hitch weight.
Adding 300 lbs on the rear bumper of a small TT IMO can make a ill handling combo. - CavemanCharlieExplorer III
MFL wrote:
Back of a TT??? NOPE...tell son to forget that idea! Best look at other options.
Jerry
I agree. - MFLNomad IIBack of a TT??? NOPE...tell son to forget that idea! Best look at other options.
Jerry - notevenExplorer IIIPlus the added moment of inertia added to the yaw or "sway" axis.
Weight added to the ass end of a RV trailer is always A Bad Thing because they are already built like a teeter totter / weather vane with their little wheels halfway up the frame. - LwiddisExplorer IIExcellent analysis.
- valhalla360NavigatorI throw some ballpark numbers around. Update them based on your specifics and you will get a fairly good approximation.
Let's say total current length is 25ft and the center of the axles is 15ft behind the hitch. The center of gravity of the bike and rack will sit 13ft behind the center of the axles. The rack will weigh 200lb.
Assuming the starting hitch weight is a healthy 15% and loaded for travel it weighs in at around 6500lb (assuming 4500 is the empty weight) results in a hitch weight of 975lb to start.
You are adding 500lb (bike and rack) should take about 433lb off the hitch leaving a hitch weight of 541lb which is around 7.7% hitch weight. That's way below the 12-15% recommended.
PS: This ignores the question if if the frame can even handle the weight. If it takes a lot of beefing up, it could easily result in the rack being 300-400lb. You also have to consider if the axles are spec'd to handle the load. In the original situation, if the weight = 6500lb with a 975lb hitch weight, the axles only have to carry 5525lb. If they put a pair 3000lb axles on that's fine. But with the bike on the back, the axles are now expected to carry 6658lb out of the now 7000lb loaded trailer. That would mean overloaded axles.
Assuming he is towing with a capable pickup, a better option would be to put the bike into the truck bed. Obviously, he would need an extra 300lb of payload but it would only require some straps/blocks to hold it in place and the trailer itself would never be compromised. - BoomerwepsExplorer
schlep1967 wrote:
I would also question the frame strength of the camper to have that weight bouncing around back there.
Strongly concur. He’ll need some significant frame/bumper reinforcement. Best to haul the motorcycle in the truck bed, if possible.
There are many tales of bumper to frame weld breaks destroying a 3 to 4 bicycle rack load. - LwiddisExplorer IIWas the trailer built for an additional 300+ pounds at the rear? Tongue weight decrease isn’t the only consideration. How much weight will the rack add to the 300 pounds?
44,028 PostsLatest Activity: Mar 27, 2025
