BubbaChris
Feb 07, 2015Explorer
Payload is something that should be on the Yellow Sticker inside the driver's door frame for your Denali. That number would be accurate for your specific build before you add anything other than a very modestly-sized driver (I believe 160lbs).
Everything else you add to the vehicle along with the tongue weight of the TT count against this total.
So if you come back with your Yellow Sticker Payload figure, folks can make more accurate suggestions about max trailer size/weight.
44,068 PostsLatest Activity: Jun 10, 2026
