Dakota98
Feb 07, 2015Explorer
kfballer22 wrote:
Weight Information
Curb Weight - Front (lbs)2923
Gross Axle Wt Rating - Front (lbs)3600
Gross Combined Wt Rating (lbs)14000
Curb Weight - Rear (lbs)2672
Gross Axle Wt Rating - Rear (lbs)4200
Gross Vehicle Weight Rating Cap (lbs)7400
I can't find "payload" reference in any of my research on my vehicle. Does the above information help? Can I tow a trailer that is dry weight of 5900lbs with this vehicle?
Was this information found online ?
If so, it is inaccurate for your needs. The information you need is on the vehicle stickers. When found, that information reflects "as built"
meaning your specific rig. Look on the drivers door jamb & in the glove box for that info. You should find defined weights & the type of tires that came on it new. Does it have a "factory" tow package ?
44,068 PostsLatest Activity: Jun 10, 2026
