Hi all, I wanted to get my numbers checked. It is a 2004 Yukon XL towing 2011 keystone summerland 26' bunkhouse BHSS. The Yukon xl is 7000 lbs GVWR, 13000 GCWR. 3000 FAWR, 4200 RAWR. I have four ki...
I am not famailer with what you are describing. You need to get a little less tension on the spring bars. Assuming the chains are where they need to be length wise now, then taking a little tilt out of the head is the idea.
