myway_1's avatar
myway_1
Weight Concern
Hello folks,
I am considering buying a 2008 Toyota Tundra Doublecab long bed 4 x 2 pickup and a Travel Lite 625 truck camper. I want to make sure that I won't have an overweight problem. I will be the only passenger. I weigh 160 lbs.
Here are the specs for the pickup in pounds:
GVWR: 7000
GAWR: 8050
Curb Weight: 5345
Payload: 1655
Reserve axle capacity: 2705
FAWR: 3900
Curb weight front: 3080
Reserve axle capacity front: 820
RAWR: 4150
Curb weight rear: 2265
Reserve axle capacity rear: 1885
Here are the specs for the camper:
Dry weight: 1285 lbs
9 gallon fresh tank. No grey or black tanks
Floor length 6.2 feet
I want to have the camper all the war forward so as to have a deck utilizing the remaining bed and tailgate.
The center of gravity will be way forward, at least 12 inches from the rear axle. The Toyota manual says to keep the center of gravity within a few inches of the rear axle.
Will I be okay with weight if I keep my stuff to a minimum and will the forward center of gravity be a problem? Anything else I should be concerned about?
Here is a write-up on the camper if you're interested:
http://www.truckcampermagazine.com/news/tcm-exclusive-2016-travel-lite-625-super-lite
Thanks for your advice.
