tkoden wrote:
Truck empty:
Front: 3450
Rear: 3350
Trailer worst case load before adjusting chains:
Front: 3370
Rear: 4530
Trailer: 6330
Trailer normal load after adjusting chains:
Front: 3600
Rear: 4390
Trailer: 6120
Your axle load measurements show some results which are not physically possible -- assuming the TV and TT loads did not change during the three weighings.
The indicated tongue weight was (3370+4530)-(3450+3350) = 1100#
The GCW "before adjusting chains" was 3370+4530+6300 = 14230#
The GCW "after adjusting chains" was 3600+4390+6120 = 14110#
The two GCW values should be the same (within the accuracy of the scales).
The load removed from the front axle, when hitched with no WD, was 3450-3370 = 80#
The load added to the rear axle, when hitched with no WD, was 4530-3350 = 1180#
That result is physically impossible.  For your TV, the load added to the rear axle should be approximately three times the magnitude of the load removed from the front.
A TW of 1100#, with no WD, should have caused about 550# to be removed from the front axle and about 1650# to be added to the rear.
The data show the load on the trailer axles, with WD applied, was 6330-6120 = 210#
LESS than with no WD.
This also is physically impossible.  The load on the TT axles must increase when WD is applied.
The data show that application of WD caused
3600-3370 = 230# to be restored to the front axle, and
4530-4390 = 140# to be removed from the rear axle.
This also is physically impossible.  For your TV/TT combination, the load removed from the rear axle will be about 1.4 times the amount added to the front.
If the scales data are reasonably accurate -- then the loading of the TV and/or TT must have changed in the course of obtaining the three sets of weights.
If the loading of TV and TT did not change -- then the scales data are not correct.
I suggest you take another three sets of axle loads, making sure that the loading of TV and TT is the same for all three sets.
Ron
