tkoden's avatar
tkoden
Weight Dist Hitch Setup
I have been playing with my hitch a lot lately and I can not get any weight on the front axle of my TV. I have the chains so tight I can barely pull them up and I am a BIG guy. The most I have been able to do is about 100 lbs of weight on the front end. Is there such a thing as having the chains too tight?
I am running a reese straight line dual cam setup.
  • Jerallen wrote:
    If you hook up as APT suggests ( and many of us do) you will find that snapping the brackets up is quite easy. The trailer tongue jack does the lifting and makes snapping up much, much easier. You will easily be able to go up several links which will restore more weight ot your front axle.
    I run 4 links under tension- my bars are parallel to the tailer frame when snapped up- and I cannot snap them up at all without using the tongue jack- and I am a fairly BIG gut also.
    That's what I do but I can barely get it to snap. If that is ok then I am fine with that setup. I am just concerned I may be putting undue force on the hitch.
  • If you hook up as APT suggests ( and many of us do) you will find that snapping the brackets up is quite easy. The trailer tongue jack does the lifting and makes snapping up much, much easier. You will easily be able to go up several links which will restore more weight ot your front axle.
  • I have 1200 lb bars. Tongue weight should be around 900 lbs.
  • What poundage are your bars rated for?
    How many links do you have under tension?
    Are you using the procedure APT mentioned?
    When snapped up are your bars parallel to the TT frame?
  • I am measuring with the axle scale at my companies distribution center so I know the weights are pretty close (+/- 10 lbs) I follow the same procedure. I am using about an 18" cheater bar / pipe that came with the hitch.
    Truck empty:
    Front: 3450
    Rear: 3350
    Trailer worst case load before adjusting chains:
    Front: 3370
    Rear: 4530
    Trailer: 6330
    Trailer normal load after adjusting chains:
    Front: 3600
    Rear: 4390
    Trailer: 6120
  • You are measuring with a scale? Are you using a cheater bar/pipe for the snap-up brackets or just by hand?
    Myself and many people follow this procedure when attaching TT to TV:
    Lower tongue on ball
    Latch tongue on ball
    Raise tongue to about unhitched ball height
    Apply WD bars/snap up
    Lower tongue
    Raising the tongue up after connected means far less pressure on the WD bars and snap-up brackets. Sometimes I snap them up by hand, but usually still use a pipe/extension for leverage.
