How do i hookup my travel trailer and get it level if i have a slight slope in my driveway. Or do i pull my trailer in the road to hookup weight dit hitch.
Initial set up should be done on a flat and level surface. Measure the trailer frame from the gound at the front and back to level it. Slightly nose low is best.
Once the hitch is set up and you know how many links to use etc, the settings usually stay the same so you can hitch it anywhere. Doesn't have to be flat or level.
