lawrosa
Mar 31, 2018Explorer
wileefox wrote:
I don't think I explained it well. I'm talking about hooking the chain into the hook and then lifting it into place and inserting the pin.
the video instructed to bring the hook assembly down to a point where it is parralel with the ground. I've been swinging it down almost to the end of its arc before hooking the chain onto the hook and lifting it into place.
It doesnt matter how far you bring the hook up and down. It matters wait chain link your using. And also after bars are tensioned that the bars are
1. parallel with the frame or with a slight downward angle
2. having a min of 5 chain links showing
3. All in relation to distributing the correct weight from scales or wheel well measurement to get the front of vehicle at or near unloaded ride height/weight.
So if you are tightening too much without a source to measure or weigh, you can essentially lift the rear of the vehicle right off the ground...
