edekgb
Oct 27, 2015Explorer
It is but I think it's the way it's mounted? I don't quite follow this but I was reading this:
'The oem weight carrying hitch (for the V6's) is mounted to the rear crossmember, underneath the bumper cover. It is rated for 500 lbs max tongue weight and 5,000 lbs max pull weight. It is NOT designed to be used with a weight distribution system, because the rear crossmember it is mounted on is not designed to handle the rotational torque stress that a weight distribution system will put on it. On the other hand, the frame mounted hitch, like those on most V8's, is designed to be used with a weight distribution system because it is directly mounted to each of the main frame rails. When a weight distribution system is used with it, the rotational torque is applied directly to the frame rails through the hitch. If you need a weight distribution system to control sway or handle a heavier trailer, you MUST have a frame mounted hitch for it to work properly and not damage the rear crossmember.
44,067 PostsLatest Activity: Jun 05, 2026
