LarryJM
Aug 22, 2014Explorer II
jaycocreek wrote:
Well Larry, here's what I'll do.. I'll give you a video link on how to hook one up from Eaz Lift hitches the right way with a bar, you post a video from any reputable WD hitch company that shows hooking up without the bar, with hands only!
Eaz Lift WD hitch setup
Your turn.
BTW below is the highlighted Cautionary Warning on page 6 of the Reese Dual Cam HP WDH system instructions:
CAUTION:
WARNING:
When lifting/lowering Snap
Up Bracket, Avoid putting any part of your body in the path of the lifting handle and under the cam arm and spring bars. Components of this system are loaded with substantial force and could shift position or drop suddenly causing serious injury or death.
Never Raise or Lower Snap-Up Brackets without raising the trailer tongue jack to remove the load from the spring bars and cam arms. Failure to do so could cause serious injury.
Now if all the armchair engineers want to recommend ignoring these IMO sage SAFETY RELATED warnings and directions that is their decision, but to support others to do the same is IMO foolish and ill founded.
Finally, I don't need any video cheat sheets since I can read and understand English perfectly well.:W
Larry
