jaycocreek
Aug 22, 2014Explorer II
CAUTION:
WARNING:
When lifting/lowering Snap
Up Bracket, Avoid putting any part of your body in the path of the lifting handle and under the cam arm and spring bars. Components of this system are loaded with substantial force and could shift position or drop suddenly causing serious injury or death.
Never Raise or Lower Snap-Up Brackets without raising the trailer tongue jack to remove the load from the spring bars and cam arms. Failure to do so could cause serious injury.
You must be misunderstanding me...Yes,you have to jack the front of the trailer and rear of the truck up to take the tension off to hook up the bars but not so far you can do it with your hands without the tool provided.
Where does it state you don't need the tool to connect the spring bars?
Where does it state if you jack it up far enough,the tool is not needed?
Please show me anything that states you do not need a cheater tool.
We must be talking about two different hitches..Gotta be.
