martipr
Sep 30, 2014Explorer
Bumpyroad wrote:martipr wrote:
You say tomato, I say tomato. Do what works for you. Although I can't imagine getting the pipe out, going back and forth from side to side, then putting the pipe away instead of just flipping a switch. I guess in 75 years I have learned to use the least labor intensive method possible.
well my jack is manual, no button pushing. and one second per side tightens up the bars. I have learned to use the least labor intensive method possible. don't know why you have to go back and forth? I don't.
bumpy
I don't go back and forth. I was referring to this by fairfaxjim on page 10: "I start with one more link on one side, then do same on other side, then go back to first side and set at normal, then do same on opposite. The lighter setting helps support the load enough to get the other side on at first."
