Huntindog
Oct 01, 2014Explorer
kend40 wrote:I don't see it as right or wrong. But which way is safer.rdhetrick wrote:
Sorry, but I don't buy that raising the jack is the "only correct" way to do it.
If that were true, then why would the manufactures bother making a pivoting bracket with a nub for the pipe? If they intended everyone to use raise the jack and flip the lever by hand, then they would have simply installed a hook on the frame for you to slip the chain link onto.
There's nothing wrong with using the pipe.
My WD hitch came with a pipe for the purpose of lifting the shackles.......so how is it not the right way???
I have a over the bed rail quad rack for the bed of my truck. It comes with 10.5' ramps. You can drive the quads up there. Or winch them up there.
I used to drive them up. I now winch them up, as it is much safer.
As I said before, we humans used to do lots of things that were unsafe by todays standards.
The hitch design in this discussion is probably the oldest one still being made today. Many people have been hurt when hooking it up. Many of us have learned from those incidents about safer ways to do it.
Before I had a power jack, I used the pipe. But I wouldn't let my wife do it. She now hitches up all the time, using the power jack method. I am comfortable with her doing it this way.
The advantage that the internet, and this forum gives us, is the free flow of information. Good and bad. You gotta decide for yourself which is good, and which is bad. But at least you are now informed.
If you are comfortable with the risk... Then continue doing it the old way. I or nobody else will change your mind, and it is YOUR risk and YOUR right.
