93Cobra2771
Jul 05, 2013Explorer
GateMaster97 wrote:93Cobra2771 wrote:
I wouldn't be concerned with age. Also, in case you didn't see my post above, your bottom mount coupler complicates things...
Sorry I'm not familar with the term bottom mount coupler... what part of this setup is considered "bottom mount" and what type of hitch can I buy that might make it simpler? Thanks!
Well explained what te bottoming coupler is a post or two down from your question.
Regarding the type hitch, a Trunion type will be easier to set up.
You will not be able to get the spring bars parallel to the frame. Most important part is you still have clearance so they won't hit in the corners.
44,070 PostsLatest Activity: Sep 18, 2026
