marauder7's avatar
marauder7
Weight distribution for a novice user
Just bought a 27ft, double axles TT that will be towed by my '07 F-150 using the manufactured installed towing system. Just reading some idea about the weight distribution bars, and how do I buy the correct WD bars w/o knowing my TW? Or can I not use the WD bar after all?
  • I've never felt the need for any additional "sway control" on my setup. I have decent TW % and the axles on my trailer are located on the rear 1/3 of the trailer, so with them being 2/3 of the way back from the hitch, I've never experienced "sway".. Even with high winds, being passed by semi's, a couple of emergency maneuvers, going down hill....
    Folks swear by those add on friction sway devices that you add to your setup. Others swear by the WD hitches with "built-in" sway control, like the Equal-I-Zer's or Dual Cams or others and they are all fine depending on what your rig needs.
    My EAZ-Lift only cost $250 back in 2002. Not sure what they cost now, but it's been a perfect setup for me.
    I've been towing trailers for over 30 years, so I've found out that just loading them correctly makes most of the difference.. At least for those kinds of trailers that you can adjust the load..
    TT's, you don't have that many options on how it's loaded because it all depends on how far back the axles are and where the storage is, or where the fresh water tank is and on and on..
    Without really knowing more about the trailer you have in mind, it's hard to say one way or the other what you might need or not..
    Mitch
  • Agree with Mitch150. I have the same hitch he does for many years. I also have a friction sway control. Good luck.
  • Thanks Mitch,
    My 27ft TT also has 5000GVWR w/c is very similar to yours, thanks. Now will I also need a sway bar that goes along with it or just a WD bar can do the job?
  • You will need WD for anything over #500 TW and #5000 trailer.
    My 22' #5000 GVWR TT has around #650 TW and I use a #1000 EAZ-Lift WD hitch setup. Been using it for over 12 years and it works just fine for me.
    Used it with my old 97 F150 and use the same setup with the 13 F150. The 13 has much more towing capacity than the 97, but I still need the WD setup..
    The "installed towing system" you refer to is NOT a substitute for a basic WD hitch setup.. ;)
    Good luck!
    Mitch
