Terryallan
Sep 25, 2018Explorer II
freddy4toes wrote:
I'm leaning towards a WDH. Thanks again for your thoughts.
Were I you. I would lean a little more. Air bags do NOTHING to return lost steering control to the truck. All they do it lift the rear. You will still have light steering that can cause sway.
A WDH returns lost steering control, and braking to the steering axle. It is as much of a safety devise, as anything on the truck. A WDH will make you more safe, AND level the truck. Win, win. If you go with the air bag. There is a good chance you will find you need the WDH as well. 12 to 1400lbs is a lot to hang off the back of any truck. Like a seesaw that weight will in all likely hood raise the front end. Even if it does have a diesel trying to hold it down.
44,066 PostsLatest Activity: May 13, 2026
