marcsbigfoot20b
Sep 25, 2018Explorer
I have a 2000 F350 dually CC long bed. My ~7200 lb TT has about 1000 lbs tongue weight with the front water tank full. I also have firestone airbags but only have them at 15 psi with the water tank full. The best part is hooking and unhooking with the airbag pressure adjustment switches, full pressure, lower the jack then let the air out and the ball falls right out without loading up and stressing the jack.
If you load really heavy you can add some air so your headlights aren’t too high.
Weight distribution hitch is mandatory. Airbags optional.
44,066 PostsLatest Activity: May 13, 2026
