webwrangler
Sep 01, 2019Explorer
happy2rv wrote:
I got tired of having to lift and carry my weight distributing hitch around to install and remove it from the truck. It's also quite awkward to store because it doesn't balance well enough to reliably stand up on its own. I looked around for a while and didn't see any solutions. So I began to think about making my own. I kicked around fabricating something out of steel tubing with casters. But I kept putting it off.
I ran across an ad from harbor freight with this mechanics seat in it and thought that looked about the right height. So I picked one up with a 20% off coupon. It's working out pretty well. I assembled it per the instructions except I replaced the seat on top with a 2x10 that I had in the garage and cut a slot just wide enough for the shank of the hitch to slide in. It would be nice if the height were somehow adjustable, but this works out to just the right height when my truck is parked in my driveway. I will probably add a bungee or some type of strap to hold the hitch in place, but for now its just sitting there and is pretty stable.
Now I just roll this up to the back of the truck, slide the shank into the receiver, install the locking pin, and roll the cart away. When I'm done, I reverse it and roll the cart with hitch on it into a corner of the garage. Side benefit, I don't end up with nearly as much grease on my hands and clothes because I don't have to lift and maneuver that beast.
You, sir, are a genius. I am getting one of those carts very soon!
