TomG2
Aug 21, 2017Explorer
Anyone who can feel a one hundred pound difference in front axle weight should be driving in Formula I. Compare front axle weights between regular cab and crew cab, between diesel and gasoline fueled models. If one or two hundred pounds made a pickup unsafe, why don't they add ballast to the front bumper of gasoline fueled pickups? They don't, because modern pickups have plenty of front axle weight no matter the configuration. The "Light front axle" feeling, if you experience it, is actually an overloaded rear suspension and or tires which allows the rear end to squirm all over the place forcing the driver to chase the vehicle from ditch to ditch.
44,025 PostsLatest Activity: Feb 18, 2025
