3oaks
Dec 16, 2015Explorer
jmtandem wrote:You got it. Simplified.How do you get the weight distributed correctly in the trailer? What are the signs that it is not? If a trailer is porpoising.. is that too much in front? Sway.. too much in rear? Any info would be appreciated!
Go to the scales. Be sure you have approximately 13 percent of the total trailer's weight on the tongue. That is it, that simple!
Also road conditions will cause proposing which cannot be entirely eliminated. Specifically concrete highways where the joints have curled over time. In this case, the only thing that helps is to adjust your speed to reduce the purposing.
