mikebte
Dec 16, 2015Explorer
mdprowash wrote:
Thanks for the replies. The sway and porpoising is nothing significant but there is a little bit. I believe my TV is adequate.. 99 2500 Cummins.
I can get fairly level hooked up. And when I measured.. the height variance at my wheel wells with weight distribution bars hooked up is about an inch.
When I had the trailer inspected I had them weigh the tongue.. it was 850# (dry) if I remember correctly. I will pick up a scale soon to see where I'm at loaded. The kitchen/pantry is up front and bedroom/storage is in back. Water tank is under sofa before the axles but usually travel with it empty. I need to get the trailer weighed while loaded. I believe dry weight is 6500 according to tag.
My weight distribution hitch is 800# rated. I usually hook it on the 6th link and have tried the 5th link but like it on 6th.. seems to ride better. I could use some heavier bars.
Truck has a leveling kit installed by previous owner that I plan on removing and i would like to add airbags in rear. I think that will help some. Shocks are Bilstein 5100s and are good.
I was looking to see if there was any rule of thumb for loading and how to distribute inside.
So..... If I am reading this right, you weight is 850 and your hitch is rated at 800?
May be passed the upper limits of that hitch. Also front leveler does not help the way it sits.
