Atlee
Dec 17, 2015Explorer II
Only if the fresh water tank is all the way forward, or all the way aft. My fresh water tank sits over the axles, so the water doesn't come into play, except if the 40 gal water tank is only half full. The sloshing could conceivably have an effect.
Lynnmor wrote:rbpru wrote:
My point is, the 1200 lbs of stuff that was added to the dry weight of my TT has an assigned spot. Not a lot of room to "balance" the load.
That's true, you are limited on most items normally carried in a travel trailer. You do have hundreds of pounds of water to play with, so that may be an option.
If you have a trailer that just cannot be balanced with the proper hitch weight, you have two option; camp in the driveway or get a better designed trailer.
