93Cobra2771
Oct 04, 2016Explorer
SQUAT in the rear isn't an issue, guys. It's how much the front comes up. Most modern truck manufacturers specify that the front of the TV should only come up half the distance between loaded and unloaded height.
The object of the WDH IS NOT to keep the rear from squatting. It is to put weight back on the front axle. If you are trying to get the rear back up to normal ride height, you are doing it wrong.
To the OP, have you spoken with equalizer about your brackets moving? What did they say? Can you get replacement spring bars?
Until you know your actual tongue weight, I'd hold off on getting a new wdh. Get your tongue weight figured out.
You can actually run 1000# bars with 1000# tongue. Or you can run 1400# bars. According to how much weight you are transferring, 1400# may make no difference. It's all about how tight you have your bars loaded.
The difference will come in how it rides. 1000# bars are going to ride "softer" than those 1400# bars. Meaning, hit a bump with 1000# bars and you could experience more oscillation than 1400# bars. The 1400# bars will be a much stiffer connection with the 1000# tongue.
With all that being said, I ran a dual cam setup prior to my hensley. If you are happy with your sway characteristics, I would determine WHY your brackets are moving around. Especially since it seems that no one else is having those issues. Could be as simple as an incorrect measurement.
YMMV
YMMV
