- rexlionExplorerI've had the Equal-i-zer and it worked well. It was easy for me to install without drilling anything. I've read that the Reese is harder to set up correctly (and RV dealers don't always get it set right, either).
The 2-point provides some anti-sway friction, but the 4-point will do more.
I liked the Andersen better than the Equal-i-zer mainly because it was easier to deal with chains than heavy, long bars when disconnecting and reconnecting. It worked just as well, too. Only, the Andersen is best for trailers under about 7K lbs as it cannot level the rig properly when there's a lot of tongue weight. - GrandpaKipExplorer II
Timtation wrote:
I found the Andersen a great improvement over the system installed on my trailer. Control, ride, ease of connection and feeling of safety all improved. Picture this, you are on a rough road, staying in your lane, getting feedback from the trailer through the hitch system, you're on edge, your wife wishes she were smaller in all possible manners related to dynamic comfort and you change systems and the feedback is reduced by 90% as are the previous objections but you find no difference in control, perhaps better control due to better attention!
As long as my load is in the range, my hitch will be Andersen.
Agree wholeheartedly. - kellemExplorerI personally prefer the Reese DC, simple and effective.
The one issue being, some trailer manufacturers install the Propane tanks forward of battery making it difficult to install chain lifts vertically of cams. - TimtationExplorerI found the Andersen a great improvement over the system installed on my trailer. Control, ride, ease of connection and feeling of safety all improved. Picture this, you are on a rough road, staying in your lane, getting feedback from the trailer through the hitch system, you're on edge, your wife wishes she were smaller in all possible manners related to dynamic comfort and you change systems and the feedback is reduced by 90% as are the previous objections but you find no difference in control, perhaps better control due to better attention!
As long as my load is in the range, my hitch will be Andersen. - ScottGNomadThe beauty of the dual cam is it actually pushes the trailer back in line with the tow vehicle.
That being said, there are lots of different technologies that strive to achieve the same thing. Some use other methods to help force vehicle and trialer in-line. I haven't tried them all but I far prefer the perfromance of the DC over the Equalizer I had. - WayneAt63044ExplorerI have used the Reese Dual Cam and my current Equal-i-zer 4 point with success. I had to switch to the 4 point when I changed trailers. The V-nose covers much of the hitch area so that there is no room to mount chain lifts. It has to be under-slung to work on my current trailer.
- LwiddisExplorer IIX2, openspaces.
- opnspacesNavigator IIThat really is a Ford vs Chevy type of discussion.They are both good in their own way and both are fairly effective.
44,027 PostsLatest Activity: Mar 05, 2025
