- aftermathExplorer IIII agree with what Nickthehunter just said. A tow rating is a decent place to start but....few half tons can actually tow the maximum weight stated without having troubles in other areas. I tow a 6500 lb trailer with my Tundra that (they say) can tow 10K lbs. With a TW of close to 1000 lbs I am close to my payload number before I even start the engine. So, look at axle ratings and payload capacities when you start to narrow your choices.
- nickthehunterNomad IIIThere are two stickers on the door of the truck. They give you information like GVWR, RAWR, max cargo (payload), that the info anyone would to tell you what you can reasonably tow. Without that info, any answers to your question have no basis in facts.
- valhalla360Navigator
dodge guy wrote:
I wouldn’t go any higher than 7k lbs loaded.
A lot of 1/2 tons shouldn't be towing 4-5k.
Others may be able to handle upwards of 10k.
Depends on the specs of the truck. They vary wildly for 1/2 ton trucks. - APTExplorer6k dry, assuming you have the HD towing package and either 3.5L Ecoboost or 5.0L V8 engines. Lots of power, but suspension and stability on the highway are the more practical limitations.
- dodge_guyExplorer III wouldn’t go any higher than 7k lbs loaded.
- SagebrushExplorerMuch less than they say IMO. The year of the truck makes a huge difference. Do you have a 2001 or a 2021? Look up the towing guide and see what your weights are for your actual truck. Then go way under the max figures if you want to enjoy traveling.
When I towed with the older F150 size trucks I preferred trailers around 6K and 25' max and the biggest engine option. I used the equalizer brand hitch set up. Trucks are rated for more GCWR now days. I learned right away I wanted a long wheel base truck with more weight though, never really liked pulling close to max with any size truck. - SkipgExplorer IIGet your VIN # and call Ford give then the # and they’ll tell what your truck is rated to tow. My 2020 F150 with max tow package is rated to tow 13200 lbs
- JIMNLINExplorer IIIDepends on the F150 gvwr rawr....engine size/tranny a drive ratio.
Ford gives the F150 gvwrs ranging from tiny 6200 lbs up to 8200 lbs and rawr from very small 3200 lbs up to 4800 lbs. And of course engine sizes from small v6 up to the 5.0....3.5 EB engines.
44,051 PostsLatest Activity: Oct 02, 2025
