Bedlam, you need a Torklift GlowLadder for that application. They are made one at a time with optional GlowLadder carrier. I haven't found a supplier for the blocks, but I'm sure the jack manufacturers will create longer jacks soon using the larger 10 in diameter jack supports to handle the extra length. Finally, normal sized FastGuns will work, but it will be a week or two before Torklift finishes their tiedown mounts for that model truck. I hear it was hard to get one into their shop to do the measurements. See their application guide for more info. :)
