JIMNLIN
Mar 03, 2016Explorer III
You'll be fine with either.
You may have some wiggle due to P tires on your Tundra as others find with P tires and max trailer size. If that happens many move up to a LT C (50 psi) or even a D (65 psi). Just make sure the Tundras OEM wheel are rated for 65 psi if you plan on using them at those pressures.
The 7500 GVWR trailer weighs 5400 dry which means it has approx 2000 lb CCC. I would guess the trailer may weigh closer to 6800 lbs when its loaded = 900-1000 lb hitch weight.
44,026 PostsLatest Activity: Feb 24, 2025
